what are these connectors for?
Old Aug 3, 2011 | 09:58 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I have reinstalled my dash in my 91 camaro and I have a few connectors that I can not remember where they go or if they are even used. Ive attached two pics. Also thereis a female plug on the stop light switch and it has 2 pins inside it but I can not locate a male plug to it. It already has a plug plugged into it at a 90 degree angle.
Attached Thumbnails what are these connectors for?-imag0345.jpg   what are these connectors for?-imag0346.jpg
Old Aug 4, 2011 | 06:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: what are these connectors for?
http://www.austinthirdgen.org/index.php?pid=19
Wiring diags - scroll way down, tons of 1992 diags (all the same for your 1991 car) - trace the wire colors to see what's what to help locate (if they are even used).
Old Aug 5, 2011 | 09:28 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The clear one goes on an add-on brake switch and is for the cruise control and the other looks like a relay connector, possibly for the starter enable relay.
Old Aug 5, 2011 | 09:53 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
White one is the brake switch cruise control and the other goes to the cruise control module and the diaphragm out in the engine.
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
