Rear Defrost Ground Wire Smoking
Old Aug 8, 2011 | 05:52 PM
Spd-Kilz's Avatar
Car: 83 Z28 / 87 IROC-Z / 95 Z28
Engine: LG4 / LG4 / LT1
Transmission: 200C / 700R4 / T56
Axle/Gears: 3.08 / 3.23 / 3.42
Hey guys, need some help...my electrical skills are slim-to-nill so I thought I'd post here first before I go any further.
I am missing the ground plug that connects to the lift shock on the passenger side, so I figured I'd wire up a temporary ground until I get a chance to find one at a junkyard or eBay. The problem though, as soon as I turned the defrost on, that ground wire would begin to smoke and get hot.
Here is the picture I'm going off, and I am missing that wire all together.
https://www.thirdgen.org/forums/atta...r-109_0901.jpg
Thanks in advance!
Old Aug 8, 2011 | 09:34 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Rear Defrost Ground Wire Smoking
What size wire did you use? How good is the ground? Defrost passes ALOT of current
Old Aug 9, 2011 | 08:10 AM
Spd-Kilz's Avatar
It was a rather small wire, all I had lying around. Didn't realize I'd need a thicker one.
Anyways, I just bought this harness kit from Brock's Camaros on eBay...has all the wiring I'll need. If that doesn't work I'll try the switch itself next (but I think that's fine since it lights up and then causes the ground wire to smoke (so it must be getting power).
http://cgi.ebay.com/ebaymotors/85-CA...item56449cf324
Old Aug 9, 2011 | 10:24 AM
Pocket's Avatar
Car: 91 Trans Am
Use a piece of 10ga and it should work fine. Do not continue to use a small wire thats smoking, you risk starting a fire
The link has more than you need. Cant really see the ground in the pic. If it comes awesome, if not clip the purple wire to length and crimp a ground ring on
eightsixseven
Dec 16, 2024 01:50 PM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
