Rear Hatch motor, Replace or Weld?
Old Aug 9, 2011 | 11:05 PM
Zero27's Avatar
Car: Red 1989 Camaro RS
Engine: 305 5.0L V8
Transmission: Auto :(
I just got my 1989 V8 RS, And the hatch motor for the "trunk" is going bad. You have to pull/push on it to make it come all the way up and down. I have heard of some people welding it in place so It will always be in the "closed" position and was wondering if anyone has done it and what the pros and cons are.
Old Aug 10, 2011 | 12:00 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Rear Hatch motor, Replace or Weld?
Repair it, dont weld it because that fixes nothing
The housings for the motors are plastic so some slob will break it when slamming the trunk vs damaging the mechanical parts. Plastic housing is available from TDS, 1A auto and ebay
Old Aug 10, 2011 | 10:35 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
also, while you're in there, it may be worth replacing the plastic sliders that the latch rides on. they get brittle and fall apart. If yours are cracked or gone, take a look over at TDS for replacements
Old Aug 10, 2011 | 11:24 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I agree on inserts. Mine were pretty bad once I tore it apart. I tried to jb weld housing once worked for awhile but eventually broke so I bought a new one from TDS. It's a stupid design IMO to have most stress on a plastic housing that's held to a metal bracket with 3 small screws.
Old Aug 10, 2011 | 11:32 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
even sillier on GM's part is that the inserts never got a part number, so they couldn't even be ordered from the dealer new!
Old Aug 10, 2011 | 01:29 PM
Zero27's Avatar
Engine: 305 5.0L V8
Yeah, I'm definitely going to check the housing and the brackets, I can still hear the motor going so hopefully its still good. But it sounds like its struggling so I will probably have to buy a new one here eventually..
What is the actual www. for TDS because when i google it all that comes up is some stock trading company..
Old Aug 10, 2011 | 01:32 PM
Engine: 383 SBC
Top down solutions. Www.top-downsolutions.com
Old Aug 10, 2011 | 02:05 PM
Zero27's Avatar
Engine: 305 5.0L V8
Thanks, I'm very new to actually working on cars. Luckily I have a few mechanic buddies.
Old Aug 10, 2011 | 02:09 PM
Engine: 383 SBC
No worries TDS instructions usually have pics and step by step directions.
Old Aug 10, 2011 | 03:10 PM
Zero27's Avatar
Engine: 305 5.0L V8
Yeah, that's cool. 1A auto has instructional videos too. Should be helpful.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
