Plug in by fuse box
Old Aug 11, 2011 | 03:36 PM
91RealSlow's Avatar
Car: 1991 camaro RS
Axle/Gears: Stock 273?
Plug in by fuse box
Is this the plug you use to "tune" it with a prom or whatever it's called? Or is something unplugged that I need to put back in
Old Aug 11, 2011 | 07:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Plug in by fuse box
It's the ALDL connector - it's for RETRIEVING the codes, not programming. To program, you have to physically remove the chip, and program a new chip to replace it with, in a small chip programmer that connects to your computer (since the factory chip is not to my knowledge "reprogrammable").
Old Aug 11, 2011 | 08:52 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
on 96+ OBDII vehicles, this port would be for retrieving codes, sensor data, and reflashing the pcm. however, 3rd gens are OBDI and have a read-only chip as camaronewbie mentioned.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
anesthes
Aug 24, 2015 08:18 PM
Moore89
Aug 24, 2015 07:06 PM
