What is this harness for?
Old Aug 20, 2011 | 03:57 AM
bdawg23's Avatar
Car: '92 Firebird + '06 Charger R/T
Engine: Firebird 3.1L V6
Transmission: Firebird Automatic
I found this harness hanging out under the steering column, can anybody tell me what it's for?
It has two purple wires, one green, one light blue, and one yellow... and I'm having a tough time following the wires
My first guess was fog light harness? My 92 Bird did not come with fog lights or power hatch release, but when I removed the bezel I found the wiring for the fog switch and the hatch switch. The fog switch had yellow and purple coming out of it ... hence the guess.
Thanks guys!!!
Old Aug 20, 2011 | 06:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What is this harness for?
That's probably a good guess. Car starts fine? Only other thing I can think of is an ignition circuit part (like the starter enable relay), thus I asked about the starting.
Old Aug 20, 2011 | 06:36 PM
bdawg23's Avatar
Oh yeah, it runs just fine
Old Aug 21, 2011 | 07:38 AM
Pocket's Avatar
Car: 91 Trans Am
Fog lights
Much too small for starter enable relay, plus 92 would have VATS, so the car wouldnt start without that
http://www.austinthirdgen.org/mkport..._foglights.jpg
Old Aug 21, 2011 | 08:18 AM
bdawg23's Avatar
thanks for the diagram, but the problem is, i don't know how to read a diagram like that
but here is my question... if that IS the foglight relay harness, will there be wires somewhere near the front bumper?
starting to wonder if it'll just be easier to buy a set of fog lights and wire it up all instead of using factory wiring
Old Aug 21, 2011 | 09:41 AM
Pocket's Avatar
Car: 91 Trans Am
You may have it but probably not. Check near the front turn signals for a 2 pin connector on both sides. Wires will be ppl and blk
Old Aug 21, 2011 | 04:02 PM
bdawg23's Avatar
ok pocket -- thanks for the advice. It's going to be a little while before I can get to it -- but I sure appreciate your help
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
z28joe2
Sep 28, 2015 05:54 PM
Eric-86sc
Sep 28, 2015 11:37 AM
efiguy
Sep 27, 2015 01:30 PM
