Light to tell me electric fan not running
Old Aug 20, 2011 | 05:06 AM
straight_pipes's Avatar
I would like to wire up either a 12v LED or my unused check engine light to come on when my electric radiator fan is off. Can anyone point me in the right direction. Car is a 91 firebird with a 350 from an older monte carlo. Its carb'd. I also have a summit fan temperate switch.
Thanks in advance.
Old Aug 20, 2011 | 07:34 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Light to tell me electric fan not running
Usual way is have light showing fan is ON. ( just a extra wire from fan relay to light)
In your case you will need a another relay to run the light so relay is turned off when fan is turned on
Old Aug 20, 2011 | 06:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
No - he 'could' use stock relay with no additional relays - but the light WILL be on always (even with car off).
Fan relay should have 5 terminals, one is not used. Connect wire to that terminal, and to positive side of the light - then ground other side of light. BUT - like I said, the light will ALWAYS be on.
To make a light that comes on when fan is off, but does not burn when car is off, you would need another relay. Wire the second relay as:
85 - 12v+ from fan positive wire (at fan or at fan relay)
86 - ground
30 - ground
87a - ground side of your light/LED
87 - not used
Then give the light/LED 12v+ from any hot-in-run source
This will do the following:
Turn on key, light is on. Car gets hot, fan comes on - this sends 12v+ to 85, 86 already grounded, so relay activated and a ground is sent from 30 to 87 - nothing connected to 87, so this ground goes nowhere. Car cools, fan turns off, thus 85 gets no power, so relay is "un-activated", thus ground is sent from 30 to 87a - your light is on 87a, and is still getting 12v+ since key is on, so light comes on.
Make sense? Use standard 12v 30 amp auto SPDT relay (about $9) any parts store.
{I think I got that right )
Old Aug 21, 2011 | 01:17 AM
Makes perfect sense... Thanks will try that. Much appreciated
BRoss99
Aug 10, 2025 05:08 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Jae992
Aug 27, 2015 09:07 AM
Omega
Aug 10, 2015 12:46 PM
