Trunk hatch electronics issue
Old Aug 27, 2011 | 04:24 PM
Hopkins's Avatar
After replacing the entire hatch "pull-down" mechanism the trunk still won't function properly. It did pull the hatch shut the first time after the install so I think it isbe a problem with returning the motor to its original position. any ideas on what's wrong/how to fix it would be greatly appreciated..
Old Aug 29, 2011 | 04:14 AM
wager420's Avatar
Car: Pontiac FIREBIRD
Engine: 3.8L
Re: Trunk hatch electronics issue
check if the motor is hot. if so, it maybe the trunk release relay. it should be next to the mechanism. look around for a relay near the trunk release.
Old Sep 26, 2011 | 11:11 AM
richy2001's Avatar
Car: 86 TTOP Black Trans AM
Engine: Base 5 Liter
Transmission: 5 Speed Manual
Axle/Gears: My Car has some
Anybody have a color wiring diagram for 84 to 86 Trans Am? I would like to see a diagram/schematicall wiring not just the one line "power wiring"diagram. There are 4 wires going to the hatch relay. I do not have a rear wiper or washer on the car. How does the hatch contact work? It does not appear to carry voltage or current, so how does it make hatch motor close the hatch. All help is appreciated. All ws fine until 2 weeks ago and I am the original ownersince 85.
Old Sep 26, 2011 | 10:29 PM
FormulaLT's Avatar
Car: 89 Formula
Cant help you with the color diagram or the relay.
I have been working on my hatch pulldown and from what I've found is that the latch itself has a switch (red arrow in the picture) that is activated when the hatch comes into contact with it. This switch, when pressed, makes the motor pull the assembly down thus pulling the hatch itself down. At the end of the "pull" the motor should click. This is reversing the motor to allow it to push up. When the latch is unlocked or released, the switch is also released and this activates the motor to push the assembly back up. And again at the end of the "push" there should be a click.
The flat rectangular contact area at the top of the trunk is for the center brake light on the hatch. Doesn't have anything to do with the hatch pulldown.
Hope that helps...
Old Sep 29, 2011 | 11:12 AM
richy2001's Avatar
Thanks for info on high hatch brake light contact plate for the hatch. I tried to figure out what the plate was for. I took apart the rear inside trim on the actual hatch and saw 2 unknown red wires going somewhere , for which there was no description in wiring diagrams.
Also thanks for picture of the lever. One must have to be a dective to figure out hatch stuff.
Many thanks, I'll see if I can get hatch to close again!
PS to moderators. It appears the hatch wiring and physical issues are a popular topic. I see Lonsal has a physical repair procedure link I copied. Does all this info deserve an electrical sticky for neophyte "mechanics" including the real wiring story?
Old Sep 29, 2011 | 04:01 PM
archhist88's Avatar
Do you have a wiring diagram or any information for getting the rear hatch motor to operate?
Paul
1988 T/A
royalrow@ymail.com
Old Sep 29, 2011 | 04:03 PM
archhist88's Avatar
Rear hatch motor.1988 T/A Do you have a wiring diagram or any repair information for the hatch?
Photo's
Old Sep 30, 2011 | 07:43 AM
richy2001's Avatar
On the forum are other threads that have wiring info. However they are one line diagrams and I thought severly lacking in helpful color coding. Member /moderator Lonsal has a complete mechanical rebuild procedure for hatch lock that you need to find.
www.austinthirdgeneration.org has wiring diagrams.
Good luck, others may be able to help you.
Old Oct 4, 2011 | 11:01 AM
richy2001's Avatar
Reply to FormulaLT
That little black lever on hatch lock was my problem. I pushed it down and motor operated hatch downward. I let it go after motor reverser clicked and the hatch lock went back up. All is working fine now. Very much thanks. Your picture should be a big help to others too!
Old Oct 6, 2011 | 12:54 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Sorry I haven't had time to answer this particular post. I've been out in the shop making some more of the guides for these pull-down units.
I'm sure I've answered every possible problem with these pull-down units at least two dozen times already and the cool thing is ALL those posts still reside here on TGO. Just do a little research by searching on my login name "lonsal". Gotta run, I have a dozen customers waiting on their guides or hatch repair kits.
Lon
Old Oct 6, 2011 | 02:42 PM
joecool1979's Avatar
Car: 1989 Chevy Camaro
Engine: 2.8L V6
Transmission: 89 GMC Jimmy Part Camaro Part Jimmy
Axle/Gears: Duno at this time
Have you checked the fuse in the fuse panel under the dash?
Old Jun 11, 2012 | 01:08 PM
Trevmust's Avatar
Car: 1986 Firebird
Engine: 5.0L V8
my dad smacked the motor on mine and it started working. lube the **** out of it
Street Lethal
Apr 30, 2019 12:14 PM
gta power
Convertibles
Sep 23, 2015 09:32 AM
hydrolic144
Sep 8, 2015 06:55 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
