ECM grounds testing, results normal?
Old Aug 30, 2011 | 10:48 PM
87350IROC's Avatar
Car: 87' IROC
Guys,
I am trying to chase down some gremlins in car. I have recorded the following measurements with the car off and the ECM unplugged.
Key off:
all ecm ground wire resistance to battery ground: 0.00 ohms
all ecm ground wire voltage drop to battery ground: 0.00 volts
Key on:
all ecm ground wire resistance to battery ground: 23 ohms
all ecm ground wire voltage drop to battery ground: 0.06 volts
I have taken the same measurements from battery ground to engine and battery ground to body and find no measurable resistance or voltage drop. So it seems like the ECM ground wires are leaking some voltage with the key on. But my numbers are pretty darn low. Is what I am seeing normal?
Thanks,
John
Old Sep 2, 2011 | 10:31 PM
87350IROC's Avatar
Car: 87' IROC
Re: ECM grounds testing, results normal?
bump
Old Sep 7, 2011 | 04:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Drop (Droplight)
There’s nothing wrong with a 0.06 voltage drop.
What gremlins are you having?
Happy Racing!
Make Noise, Turn Left, Repeat
GTAman
Mar 15, 2019 11:40 AM
Glowsock
Aug 31, 2015 09:01 PM
Jae992
Aug 27, 2015 09:07 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
