83 Z-28 Power Windows prob
Old Sep 2, 2011 | 08:05 AM
smoothjazz's Avatar
Hi All,
I just recently replaced my aging power window switches on my 83 Z.
Passenger side works great.Driver side works when it wants to.Could a
faulty window motor be causing the prob,or a wiring issue?
Old Sep 3, 2011 | 06:58 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 83 Z-28 Power Windows prob
you'll have to do some testing for power - check before the switch and the motor. if you've got solid power at the motor, sounds like you may have a bad motor. also, try swapping the switches and see if the problem follows the switch or stays at the driver window. also check your grounds, they can get rusty or loosen up over the years
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
