O2 Sensor Question
Old Sep 6, 2011 | 07:15 AM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 2.73 installing the 3.73 soon =D
O2 Sensor Question
Okay, so the o2 sensor is in the header, obviously, but I found another wire dangling that appears to come from the same place as the one that attaches to the o2 sensor, its a green wire with a little grey connector but it doesn't attach anywhere, does anyone know what it is? And more importantly, where does it go?
Old Sep 6, 2011 | 07:56 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: O2 Sensor Question
What style connector is it ?
that would give a better indication where it goes
Old Sep 6, 2011 | 08:26 AM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
http://s290.photobucket.com/albums/l...t=P9060016.jpg
The one that isn't the O2 sensor connector
Old Sep 6, 2011 | 05:28 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
it should go your temp sensor on the driverside head. that wire runs your temp gauge
Old Sep 6, 2011 | 06:36 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Hmm, that's right by my driver side header correct? Because thats got a round opening like the passenger one but it wouldn't work on that =\
Old Sep 6, 2011 | 06:45 PM
travis401's Avatar
Car: 91 Camaro RS
it should have a round connector on the temp sending unit, the connector slides on through the opening on the end
Old Sep 6, 2011 | 06:52 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
The temp connector on my passenger side is hooked up this can't even reach the one on the driver's side anyway
Old Sep 6, 2011 | 06:58 PM
travis401's Avatar
Car: 91 Camaro RS
you should have 3 connectors for the cooling system, one is on the top of the intake, by the water neck, thats the temp sensor for the ecm. there should also be a thermal fan temp switch on the passenger side. it turns the fan on. then theres the temp gauge sending unit, thats on the driver side head and uses that connector.
unless someone at some point moved the temp gauge sending unit to the passenger side that wire should be on the driver side. the sending unit should look like this...
does your temp gauge work?
Old Sep 6, 2011 | 07:03 PM
travis401's Avatar
Car: 91 Camaro RS
theres also another round connecter on the passenger side that looks like this...its the knock sensor and has nothing to do with the cooling system.
Old Sep 6, 2011 | 07:25 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
This is the wire in question: http://s290.photobucket.com/albums/l...t=WirebyO2.jpg
This is the passenger side temp sensor: http://s290.photobucket.com/albums/l...tempsensor.jpg
This is the driver's side one:http://s290.photobucket.com/albums/l...tempsensor.jpg
This is the wire that goes to the passenger side temp sensor: http://s290.photobucket.com/albums/l...ireforTemp.jpg
Old Sep 6, 2011 | 07:28 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Also, the passenger side sensor was replaced thats why it looks different, sorry if I'm wrong about anything, I am not exactly skilled with cars yet.. lol
Old Sep 6, 2011 | 07:32 PM
travis401's Avatar
Car: 91 Camaro RS
the "temp sensor" on the passenger side that youre refering to is the knock sensor. the one on the driver side is the temp sender. the green wire with the gray connector goes to it and runs the temp gauge. the wire might be wrapped around something/tangle up behind the block, but its supposed to be on the driver side, and on that sender in the head.
Old Sep 6, 2011 | 07:34 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
I thought the knock sensor was lower on the engine?
Old Sep 6, 2011 | 07:37 PM
travis401's Avatar
Car: 91 Camaro RS
usually it is, i cant remember if the fan switch had the same style connector or not, either way, thats were the fan temp switch should be located
Old Sep 6, 2011 | 07:39 PM
travis401's Avatar
Car: 91 Camaro RS
actually i just looked it up, the knock sensor and fan temp switch do use the same style connector, so thats the fan switch, not the knock sensor
still has nothing to do with the temp gauge though.
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
I see, I actually don't have any wires that lead to the driver's side for the temp sensor, I'll try to sort it out, but do you have any idea what the wire I originally asked about is??
Old Sep 6, 2011 | 07:41 PM
travis401's Avatar
Car: 91 Camaro RS
the wire you originally asked about is the temp gauge wire. its supposed to be on the driver side of the engine and connects to the temp gauge sender that is in the driver side head
Old Sep 6, 2011 | 07:42 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
I see, well my temp gauge worked before I replaced that sensor, now it does not my car has many issues.. ha
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
How does it connect to that sensor though? This has a connecter that is flat and rectangular
Old Sep 6, 2011 | 07:44 PM
travis401's Avatar
Car: 91 Camaro RS
if you looks at the sender, its got a round peice on top with a little groove under it, that round peice slide into the rectangular opening and the connector sits on it "sideways"
Old Sep 6, 2011 | 07:45 PM
travis401's Avatar
Car: 91 Camaro RS
hook that back on there and your temp gauge will start working again
Old Sep 6, 2011 | 07:52 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Do you have a best friend? Because it could be me now!
Old Sep 6, 2011 | 07:53 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Thank you very very much, when you said sideways I ran out to my garage checked, and sure enough you were very correct, I apologize for doubting you
Old Sep 6, 2011 | 07:54 PM
travis401's Avatar
Car: 91 Camaro RS
not the first time ive had to explain how that connector goes on....gm had to make it different for some strange reason.
Old Sep 6, 2011 | 07:55 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
Yea, I was thinking it pushed into it, and I was like... but that wouldn't work, so next gauge to fix on my list is the gas gauge, and the car will be 100%
Old Sep 6, 2011 | 07:56 PM
travis401's Avatar
Car: 91 Camaro RS
whats up with the gas gauge?
Old Sep 6, 2011 | 08:00 PM
MeisTravis's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI
It never reads correct, when I first got the car it needed a new fuel pump, and I went the route of cutting a hole above the tank and changing the pump out, I think when I put it in it went in at an angle, but I actually have a new full exhaust for my car plus a new axle, so while it's down that far I am gonna drop the tank off and see if I can straighten it out
Old Sep 6, 2011 | 08:06 PM
travis401's Avatar
Car: 91 Camaro RS
dont forget to ptach the hole you cut while the tank is out.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
