1986 z28 cluster tach
Old Sep 9, 2011 | 10:30 PM
Banditz's Avatar
Car: 2004 gmc Canyon, 1986 z28 t-top
Axle/Gears: NO CLUE!
Hi guys, looking to find out if I can just swap out the individul tach itself from one camaro to another? not the entire cluster..but just the tach? I have done a 350 swap and have yet to hook up the tach. But am highly doubting it is gonna function correctly. So...if that's the case I already have my gauge bezel off and noticed its fairly easy to just pull the tach itself right out!
I guess my question would be easier if i stated it plainly.
I want to swap out my tach (if broken) with one from the junk yard. Can I do this without swapping out the cluster? I would rather have one that went higher..mine tops out pretty low..lol. Is that easy to do, or must I get one exactly like mine?
Also..hooking up the stock tach to a swapped 350 means obviously hooking it up to the distributer..BUT what wire am I supposed to hook up to it? I have looked at all the wiring diagrams on here and the best i can tell, the white wire coming from the back of the gauge cluster..but does that wire come into teh engine bay where I can tag onto it?? If so that would be awesome! Only thing is..I have several white wires!!! LOL I don't mind playing switch a roo until i found the right one..BUT i dont wanna do that and find out I was wasteing my time. Thank you all!!
Old Sep 9, 2011 | 10:39 PM
Banditz's Avatar
Re: 1986 z28 cluster tach
http://www.austinthirdgen.org/mkport..._1987_C100.gif
For any future viewers...this should clear some things up! LOL Wish i would have found this searching before i posted up asking for tach help!
Old Sep 10, 2011 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You should be able to swap V8 to V8 tach. No need to remove the cluster. All can be done from the front in a matter of minutes. When I swapped to my 350/330, I wanted a higher reading red line (5500), so I located one in a yard and simply swapped the new for the old. Zero issues.
JamesC
Old Sep 10, 2011 | 12:41 PM
Banditz's Avatar
Hmm, thank you! Off to the junk yard i go! there's a pull a part. close to me and they are always dirt cheap!
Old Sep 11, 2011 | 02:03 AM
Banditz's Avatar
Well, found the white wire and hooked her up to the MSD dist. Yeah, its a no go....lol she is NOT working at all. Now I gotta try to find one!!
Old Sep 11, 2011 | 12:40 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
just make sure its out of a v8. the v6 tach wont read right, for obvious reasons.
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
Z28camarokid
Sep 9, 2015 11:59 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
andy74
Sep 3, 2015 08:41 AM
