A little dash gauge and light help, think I have it narrowed down
Old Sep 10, 2011 | 11:34 AM
Jerome Casi's Avatar
Car: 1989 Camaro RS
Engine: 355
Transmission: 5 speed Manual
Axle/Gears: Stock
89 Camaro.
Does anyone have a write up of what pins should see 12volts and which are grounds on the two pin sets that the gauges plug into?
Basically I am starting to think maybe it is my ribbon on the gauges that are bad. Simply because I find the pin for the right blinker ilumination light, turn on the blinker and it blinks as it should. Blinker is off, no power going to that pin, however, when I plug the dash in that blinker illuminator light stays on all the time when the headlight switch is activated. Still blinks though when you trigger the blinker, but when it cancels it stays on, even though there is no power to that pin.
Please tell me I am on to something and how I can further test this and fix it. Have my guages never work and half my illumination lights in the dash never work either.
Thanks a bunch!
Old Sep 10, 2011 | 11:45 AM
Car: 1989 Camaro RS
Engine: 355
Axle/Gears: Stock
Re: A little dash gauge and light help, think I have it narrowed down
Im basically hoping it is this simple, if the pin is flashing only when the blinker is on, but then put the cluster in and then that illumination light stays on it must be getting power from somewhere else within the gauges. (Has to be the shared ground right?, but then Im confused why half my lights work and half dont)
Old Sep 10, 2011 | 03:30 PM
Car: 1989 Camaro RS
Engine: 355
Axle/Gears: Stock
Problem Fixed! Went and found another bare cluster bin at a junk yard snapped it in and most of it worked. Thanks for the help from everyone on the previous posts.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
