Parking Lights Strange Headlight Switch Issue
Old Sep 27, 2011 | 06:46 PM
florida_gators's Avatar
Car: 1990 Firebird
If this has been covered, please admonish and redirect. (I did search...)
When I engage just my parking lights on my headlight switch (top right button), it makes my headlights pop up (just as if I turned on the headlights). If I recall, this shouldn't be happening. Just the side markers and tail lights should turn on, with the headlights not raised, right? I swapped out the headlight switch with two known good ones...same thing. I swapped out my headlight control module with a known good one...same thing. What's going on?
Old Nov 1, 2015 | 09:55 AM
gormant1's Avatar
Car: 91 Firebird Formula
Transmission: 700-R4
Re: Parking Lights Strange Headlight Switch Issue
Did you ever figure out the cause of this? Im having the same issue.
Old Nov 8, 2015 | 10:47 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Two of my customers wrote in their review of my TDS 209280 Deluxe Headlight Repair Kit that the kit also stopped this issue for them. What I suspect is happening is that there is stray electricity leaking from the parking light circuit of the headlight switch to the headlight on circuit and through the headlight control module and out to the headlight motors. It will take less power to get those motors to move if the bushings inside are broken into chunks. By repairing the headlight motors with new Delrin bushings the headlight motors will require more power to start them in motion than this small stray amount that escapes across the switch. If your headlights are in need of repair, the kit may solve two problems. However if you have already repaired them, then replacing the headlight switch is the recommended solution.
Lon Salgren
Top-Down Solutions
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
