Need Help With Electrics
Old Oct 18, 2011 | 04:34 PM
wilhay's Avatar
Car: 1984 Sport Coupe
Engine: v6
Transmission: 5spd.
Have 84 sport coupe. Problem is this, the what I assume is the ecm (under dash box at drivers right knee where you plug in diagnostic equip.) is clicks like a clock. When it does this the battery idiot light flashes at the same rythm and at night with the lights on the headlights flicker at the same rythm. Anybody ever seen this and know what the problem may be?
Old Oct 18, 2011 | 04:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need Help With Electrics
ECM is on the passenger side. The convenience center is near the ALDL, and the clicking you're hearing is the choke relay.
Check your alternator.
Old Oct 20, 2011 | 02:57 PM
wilhay's Avatar
Engine: v6
Transmission: 5spd.
Is that to say the relay is ok but I possibly have a bad alternator? The reason I ask is because the car most of the time idles very fast and the choke is not sticking and when you mentioned choke relay I thought that might be causing the fast idle situation.
1992Z28!
Nov 19, 2015 07:33 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
