hatch motor.
Old Oct 13, 2011 | 08:21 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
hatch motor.
first off,the maintanence manuel dosn't show a wireing diagram on the hatch motor part of the wireing system. I think somthing in the hatch pull down motor part of my wireing is killing my battery.Had no trouble until I fixed the swithch contact plate in the back so the top and bottom would line up.The motor was so hot after I opened it that I could hardly hold my hand on it.The motor isn't pulling the hatch down 100%.the switch in the front isnt working.and i open it from the key hole.I have to trip the switch in the latch and it gose down a little.then again for it to come up so I can close it.right now I got the motor wires disconected with the motor asembly up enuff to be able to get it to latch.but that wont keep the water out.Any help would be great.
Old Oct 13, 2011 | 09:16 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: hatch motor.
You might have to adjust the bracket on the slider mount. Thats what I had to do.
It worked fine once adjusted, it just kept pulling down before I ajusted it.
If you have the same one I do, i have a 89 Rs. Not sure the motor mount is the same.
I know the 92 is different then the 91. Was a thread on her about it.
Hope you can get it fixed. Once they work good they are awesome!
Old Oct 14, 2011 | 11:07 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: hatch motor.
mine is on a 89 iroc.There is a broken bushing that I can see on the top.mybe more.I wonder if I can buy a new set of bushings some where.
Old Oct 14, 2011 | 11:37 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
Re: hatch motor.
good luck finding the bushings, i had to go out to so many different junkyards until i found my particular bracket and bushings that slide evenly with my hatch. They made 2 different bushings and brackets. 1 setup they used various years on the bushings will be very thin, and then you have a fat bushings 8 all total if (cracked). Did you also check the plastic gear that turns when motor goes up and down?
Old Oct 15, 2011 | 12:15 AM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: hatch motor.
For all the aggravation, I would look at Moderndaymuscle.com for motors (about $23) or Topdownsolutions.com for the wiring harness around the "trigger" switch for the pull down.
Old Oct 16, 2011 | 02:24 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: hatch motor.
All the parts including the guides are available from my web site. The Guides are TDS p/n 101170: $24.25.
Lon
Old Oct 17, 2011 | 11:48 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: hatch motor.
thanks for the help.
Old Oct 17, 2011 | 11:57 PM
Engine: 5.7 LS1
Re: hatch motor.
Lon
dangit wish i knew about your site, you have everything. Would have saved me a bunch of headache and searching. Definitely book marking your site for future
Old Oct 18, 2011 | 09:33 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
Re: hatch motor.
how you book mark stuff
Old Oct 20, 2011 | 04:41 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: hatch motor.
I used Lon's kit to rebuild mine, working great for 4 years.
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
formula00ra
Sep 28, 2015 11:50 AM
