Wierd radio problem
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
Wierd radio problem
Im trying to fix the wiring mess the previous owner did. My radio will turn on but I usually dont get any sound out of it for some reason. I found that if I open the drivers door and shut it again the radio kicks on for a few seconds. What would cause this, a loose wire connection somewhere or maybe a short to the body?
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Wierd radio problem
Car: 1991 RS
These old cars always have screwed up stereo wiring because of some previous owner. You could possibly have a short on a speaker wire going into one of the doors but that would usually only knock out that speaker. But it is possible its shorting the output on the unit. Definitely check the wires running into the doors as well as the wiring behind the head unit it self. Probably should start with the driver door seeing as you can open/close it and get sound going again.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
its a short in the speaker wire. opening and closing the door josles it around to get it unshorted for a little while. its probably just a poorly/incorrectly spliced wire thats making contact with either another poorly/incorrectly spliced wire or a piece of metal.
it was a blown fuse in the aftermarket radio wiring
Ghettobird52
Jul 5, 2024 11:18 PM
Chuck84TA
Aug 27, 2015 11:14 AM
db057
Aug 11, 2015 10:11 PM
