Help please cant figure this out!
Old Oct 26, 2011 | 09:25 AM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
I took my tail lights off to clean them up and polish them. Before I put them back on I checked to see if all the bulbs are good. I replaced the bad ones and found that the only light that doesn't work is the one between the reverse light and the other brake light on both tail lights. Fuse is good. Brake switch is good. Anyone have any ideas what it could be? Thanks
Old Oct 26, 2011 | 10:44 PM
Engine: 5.7 Liter
Re: Help please cant figure this out!
Someone has to have some ideas on how I can solve this problem I am having.
Old Oct 27, 2011 | 12:49 PM
Engine: 5.7 Liter
Does anyone know if you turn on your headlights on, do your rear turning signals (LH and RH) light up? Just for night time.
Old Oct 27, 2011 | 01:13 PM
luckydog0_18's Avatar
Car: 1986 camaro iroc-z28
on my 86 iroc the light thats between the reverse and other brake light is on the side and its the license plate light that works when the parking and/or headlights are on
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No.
JamesC
Old Oct 27, 2011 | 01:23 PM
Engine: 5.7 Liter
So there is only two light on each side on when you turn the headlights on? Corner and the next one in?
Old Oct 27, 2011 | 01:35 PM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Correct.
Assuming this is a car built for the American market it will have five lights on each side from outside in:
Brake/Tail
Brake/Tail
Blinker
Reverse
Plate Ilum.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
