Disaster! Headlights/speedo importance
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I bought this 1989 Pontiac Firebird today and headlights don't come on. They don't pop up automatically but right now I just want them to work. Another thing, dash lights do not work nor do any of the gauges. However, the idiot light cluster does work. This car is a wiring nightmare where someone has cluster****ed up wiring to the fuel pump, destroyed interior and cut radio wires, a/c gauge doohickey is laying on floor with about fifty gagillion wires going to nonexistent subs and amps. The most important thing to me right now is getting my head lights working, and then dash lights.
Oh, and left turn signal works but right does not. The rear turns on but does not blink.
5.0/5Speed
5.0/5Speed
Transmission: WC T5
Re: Disaster! Headlights/speedo importance
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
wiring issues arent all that easy to diagnose over the web. from the sounds of it the wiring is all screwed up. id make friends with someone who knows wiring and get to work. its not gonna be something thats fixed over night....
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.73, Detroit Trutrac, 10 bolt
Either learn to rear wiring diagrams, learn yourself how to use a multimeter and ohms law, and get a Haynes manual, or just take it to an electrical shop and tell them the circuits you want fixed.
Car: 91 Camaro RS
if its the dash hnaress thats all chopped up would that require pulling the dash to get it swapped?
Transmission: WC T5
I got a friend who is good at electrical, were going to go through it but I'm more of a mechanical everything type guy. My Chiltons is in the mail, invaluable books!
Transmission: WC T5
Well here's a question, is there any possible way I can just get my headlights to work temporarily at the very least?
Transmission: WC T5
If anyone cares, I rewired it, headlights pop up at a flick of the switch, turn on and every single light works. My speedo and odometer do not work but I imagine it has something to do with the disconnected plug near my trans. VSS?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
a unplugged vss would cause the spedo not to work
Transmission: WC T5
I have a five speed, so no converter lock up... The VSS does plug in at trans right?
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
VSS plugs into the tailshaft, reverse lights are higher up on the trans IIRC.
ZZ3Astro
Aug 13, 2019 12:57 AM
