smog egr delete, wiring ecm trick b10 ground
Old Oct 27, 2011 | 08:14 AM
kreator33's Avatar
hey, im sorting out a wiring for my tpi set up,deleteing all i dont need, i have a tpi swap manual here,and for egr,and air and a bunch of stuff, it tells me to trick the ecm by hooking up the b10 orange terminal(the park neutral safe swith) to the common grounds,,,now do i unhook it from the ecm pluggin and hook to grounds,or do i leave it plugged in the ecm and just jump it with the grounds,,or is it something else,its not clear
Old Jul 3, 2012 | 06:09 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
Re: smog egr delete, wiring ecm trick b10 ground
I was getting a code 24 when I deleted my EGR.
Coincidentally, I converted my AT to a T5.
I shorted B10 coming from the ECM to A12 (Common Ground).
Result: no more code 24 and nothing else "weird" too
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
Jae992
Aug 27, 2015 09:07 AM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
