wiring
Old Nov 10, 2011 | 07:04 PM
19f0rmula88's Avatar
Car: 70 Chevelle
Engine: 396
Transmission: TH350
Axle/Gears: 10 bolt 3.73
wiring
going to be dropping an engine to a firebird tomorrow. the car is literally just a shell. with all suspension and body panels. no wiring harness interior engine or trans. so im getting an engine tomorrow and just want to wire something up to like a toggle switch to just crank the engine when i drop it in to get it broken in. what amp fuse will i need? and what gauge wire will i need to run from the starter?
Old Nov 12, 2011 | 07:39 AM
Pocket's Avatar
Car: 91 Trans Am
Re: wiring
I see this ending badly
Get a universal harness or replace whats missing. If you have to ask, then cobbling something together probably isnt something you're capable of doing
Old Nov 12, 2011 | 01:40 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: wiring
if its carbed you can do it, just be sure your neighbors like you since running an engine in the garage with open headers/manifolds is LOUD. all a carbed motor needs is power to the dizzy, and power to the starter and gas in bowls. youll need a pretty thick wire to run to the starter, then only about 12-10 guage for the starter soleniod. youll need to wire the dizzy to a toggle or the only way to kill the engine will be to pull the wire out of the dizzy.
if its fuel injected, then youre screwed without a wire harness.
Old Nov 12, 2011 | 01:47 PM
travis401's Avatar
Car: 91 Camaro RS
Re: wiring
actually i just found ur other post stating is a CC carb. you need the ecm and wiring for it to do anything. or you need to swap it to a non CC carb and vacuum advance dizzy.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
