Quick Fuse Question
Old Nov 15, 2011 | 07:33 PM
WhiteTrashStory's Avatar
Quick Fuse Question
Hey guys, quick question. Which fuse should I check for my illumination dash lights on a '92 Firebird. The dash lights are the only lights in on/in the car that don't work. Is there even a fuse that only controls these illumination lights?
Old Nov 15, 2011 | 08:12 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
Re: Quick Fuse Question
there should be a fuse that says gauges which is a ten amp fuse and the other one i would say is the ACC fuse
Old Nov 15, 2011 | 08:23 PM
Where do I go if these fuses are okay?
Old Nov 15, 2011 | 08:46 PM
Car: '90 Camaro
Engine: 305 tbi
check your wires or take your gauge cluster out and see if your lights are good.
Old Nov 16, 2011 | 10:33 PM
Guess it's a good time to go ahead and put some new gauges in. lol Thanks, Ty.
Old Nov 28, 2011 | 10:08 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Before you go to all that trouble, check the dash dimmer located above the headlight switch. It's possible that the problem is right there, so even if you changed out instrument clusters you would be saddled with the same issue. Also look at the wiring diagrams at austinthirdgen.org. You'll find it under tech articles.
Ghettobird52
Jul 5, 2024 11:18 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
