took ecm fuse out and it still runs.
Old Nov 15, 2011 | 06:47 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
took ecm fuse out to change vss.(didnt feel like unhooking batt.) anyway forgot to put it back in. but car still runs as usual. does that mean ecm bad? got( code 32) awhile back an still get it after two miles .but thought it was for egr. so i put new solenoid,vac line and egr valve on it. idk, but i want to know why it runs w/o ecm fuse in.
Old Nov 17, 2011 | 10:14 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Re: took ecm fuse out and it still runs.
Two things come to mind. There are often two fuses labeled ECM, one for the engine control and the other for the VSS, ABS, and such. And could you have taken out the fuse that is actually below or above the ECM fuse? Confusing under there sometimes.
Old Nov 18, 2011 | 05:27 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
no. its the ecm fuse. idk but it bothers me for some reason.
Old Nov 28, 2011 | 03:42 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
ECM Magic
There are 2 other battery lines going to the ECM.
Happy Racing!
How bout those too scared to drive without headlights in the daytimeand the ones that need headlights for a little rain
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
