Alternator not charging
Old Dec 31, 2011 | 09:07 AM
  #51
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Re: Alternator not charging
I have a theoretical idea that might work.
AFAIK, the red wire that goes to the junction box (with all the fuses), and that red wire that goes to the alternator are connected together at the battery, correct?
To rule out the battery, as long as those two wires (+) are connected, you should be able to start your car, then remove the + cable ONLY with the car running. JUST MAKE SURE IT DOES NOT TOUCH ANYTHING, ESP METAL FRAMEWORK. Record the voltage at the alternator.
If you have 13-14v after the battery + is removed, then it would indicate an issue with the battery.
If you are risk averse, lol, then I would suggest jumping 12v from bat to the redwire pin, and brown wire. See if it causes your alternator to start working. It doesn't make sense for their machines to show it outputting correctly, then on your car it's dead weight.
Another theoretic test would to be to remove your serp belt, jump the alternator wires (red/brown) or maybe (red/brown&white) to batt (+), and try to spin the pulley. If there is no resistance, there's a prob with the alternator. Because when the field coil is energized, that is what puts a load on the serp setup, creating A/C current as it turns....so by hand you should feel resistance if it's working.
Old Dec 31, 2011 | 09:16 AM
  #52
kimberanton's Avatar
Car: 89 IROC-Z28 Camaro
Engine: 350 TPI IROC
I'm by myself, it won't stay running long enough to remove the battery cable to check the volts, I have to remove the alt wires to keep the motor running.
Old Dec 31, 2011 | 09:19 AM
  #53
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
Which alt wires do you remove. The plug, or the main power cable?
If you leave it plugged in when you start it, does it die or something?
Old Dec 31, 2011 | 09:22 AM
  #54
I took the clip apart, I pull the small wire to keep it running. Yes, if I leave it plugged in it only runs for 1 or 2 secs then dies.
Old Dec 31, 2011 | 09:25 AM
  #55
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
What small wire? What is the color?
Old Dec 31, 2011 | 09:27 AM
  #56
john36mc's Avatar
if you have 12 volts at both it should be charging. one is the charge wire the big one and the other one when it has 12 volts tells the alt to charge its called the exciter wire . if you have power on the little wire .That is telling the alt to charge. its getting a signal.the little wire should have NO power with the key off did you check that?
Old Dec 31, 2011 | 09:30 AM
  #57
Sick92's Avatar
Car: 92 Camaro RS
Engine: 350 LT1
Axle/Gears: 4.10
If you have to remove a field coil wire for it to stay running, something tells me perhaps your engine isn't running good enough to handle the additional load of the alternator. Perhaps a faulty IAC
Old Dec 31, 2011 | 09:38 AM
  #58
Brn/wht or tan/wht
Old Dec 31, 2011 | 09:41 AM
  #59
Do you mean the iac motor?? I already replaced that if so. Yeah cause if I need a jump start I have to unhook the cables or it will kill the motor.
Old Dec 31, 2011 | 09:42 AM
  #60
I don't have a dmm right now, gonna pick one up in a short bit.
Old Dec 31, 2011 | 09:51 AM
  #61
My buddy is on his way with a dmm to triple check the volts on all alt wires.
Old Dec 31, 2011 | 11:10 AM
  #62
14 volts from main alt wire in back of alt.
Old Dec 31, 2011 | 11:12 AM
  #63
john36mc's Avatar
its charging
Old Dec 31, 2011 | 11:13 AM
  #64
It just won't stay running with alt plugged in.
Old Dec 31, 2011 | 11:16 AM
  #65
john36mc's Avatar
is the battery any good? load tested?
Old Dec 31, 2011 | 11:17 AM
  #66
Yes, hooked up a new battery.
Old Dec 31, 2011 | 11:18 AM
  #67
Out of a car that runs fine.
Old Dec 31, 2011 | 11:32 AM
  #68
john36mc's Avatar
can you try to unplug your fans .I dont know what to say .you must have a major draw
Old Dec 31, 2011 | 03:42 PM
  #69
It will run longer if lights, air, radio, and hazards are on. I think it's over charging.
Old Dec 31, 2011 | 04:15 PM
  #70
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
if your alt is working correctly then if you pull the positive battery cable, yes the car will stay running. i usually remove the battery cables from a dead battery and hook the jumper cables directly to the now unhooked battery cables to jump start a car. if the battry is dead enough itll pull down the voltage from the car youre trying to jump it with and not let it crank over.
pulling the battery cable with the car running is a great way to test if the alt is fried or not if you dont have a volt meter.
Old Dec 31, 2011 | 04:27 PM
  #71
john36mc's Avatar
he tested it today he said he had 14 volts. did you disconect the fan?? the ac turns on the fans
Old Jan 1, 2012 | 06:33 AM
  #72
Haven't tried the fan, will do so after work today. I noticed only 1 fan running yesterday though.
Old Jan 1, 2012 | 06:35 AM
  #73
john36mc's Avatar
the fans will draw a lot of power if its shorted. but it should have a inline fuse but some people hard wire them .
Old Jan 1, 2012 | 06:38 AM
  #74
All fuses are good but I don't trust the wiring, this is a different motor than what came in the car.
Old Jan 1, 2012 | 06:45 AM
  #75
john36mc's Avatar
the fans are on a separate fuse by its self near the battery if there still there and not hardwired.
Old Jan 6, 2012 | 04:42 PM
  #76
z285.0h.o.'s Avatar
to: oif0709.....I have a very similar sounding problem with my car. Except on mine the alt. puts out 11.8-12.1 at an idle but if if you rev the engine up to about 3 grand or so it puts out 12.3and climing does yours do that?
Old Jan 6, 2012 | 07:32 PM
  #77
I just had mine rebuilt from an original and I'm waiting for the new wire harness for the alternator to come in tomorrow. I've never had one do that, it should be 14-15 volts though.
Old Jan 7, 2012 | 08:10 PM
  #78
BApower's Avatar
Car: 2500hd,is300,91z,03pete379
Engine: 6.6,3ltr,lt1,600hpC15
Transmission: auto,auto,t56,13spd
Axle/Gears: 373,?,410,370
A few months back I traded my 89 ttop iroc for a 91 z28 conv. Needs paint and the motor in it now is some old truck motor with 882 heads(junk). Well the first time I drove the car the serp. belt broke and the water pump was leaking badly. So i got new belt new water pump put on the pump and then belt (snap) there went the damn bracket for alt and ps pump and also broke ear off alt thats on top where bolt goes. I got new (3345611 ultima) from oreilly auto parts well put it on car(not charging) tried another today not charging either. ideas anybody???????????? Oh maybe one day when i get some of the bugs worked out where i can drive it down the road them im going to borrow intake setup from a buddy AND SPRAY THE BOTTOM END OUT OF IT. maybe 300-500 shot. If i can I will put it on youtube
Old Jan 10, 2012 | 07:54 PM
  #79
Where can I get a good engine wire harness, and a good frame shop by KCMO
Old Feb 6, 2012 | 12:07 PM
  #80
putting a new wire harness to finish EVERYTHING under the hood, nothing has more than 100 miles on it, need a little help and tips on changing it, please help
Old Aug 30, 2014 | 01:21 AM
  #81
lt4orbust's Avatar
Just a fyi , Check for voltage drop at the battery connections, Long story short.... don't overlook the crimped wires at the battery, starter and fuse link bar , some of the problems others have posted sound like bad connections within the battery cable where the alt wire connects. I know it's an older post but it shouldn't be overlooked. They may feel tight and look good but have a high resistance that can cause alternators and batteries to look bad.
Old Aug 30, 2014 | 10:16 AM
  #82
formula1LE's Avatar
Car: 89 forrmula
Engine: 350 TBI
Axle/Gears: 3.55
I would hope over 2 years later he has it figured out....lol
Old Aug 30, 2014 | 11:03 AM
  #83
lt4orbust's Avatar
I know....I've been going through forums looking for problems like mine, low to no charge during warm-up(sometimes normal charging). Figured it might help somebody else?
I wasted so much time on a bad connection that looked good and had no signs of corrosion
Old Sep 30, 2014 | 08:37 PM
  #84
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Originally Posted by zegman
Check the "fan" fuse in the fuse block under the dash. This circuit supplies power to both the fan relay and alternator.
You are awesome, this is why my alternator wasn't working on the car ive been putting together for 5 years. Thanks!
Old Oct 1, 2014 | 12:27 AM
  #85
lt4orbust's Avatar
an old post helps after-all......just saying....good luck
Old Oct 6, 2014 | 11:35 PM
  #86
88Camiroc's Avatar
Car: 88 iroc
Engine: 350 4-bolt main 010 bored .040 over
Transmission: t-5 manual
that is weird normally its a fuse but im glad that you figured it out
Old Mar 30, 2018 | 03:37 PM
  #87
dirtwad's Avatar
Originally Posted by oif0709
I just bought a brand new alt and battery and it still isnt charging. It is reading 12.5v with the car running and that is with ntn on. I put the lights on and it drops to 11 volts. and stays there for a little bit. I have been trying to trace the wires down with little luck. there is a prong going into the back of the alt with three wires. One is red, the other brown and the last brown with a white stripe. If one of these wires is messed up, will that cause it to not let the alt charge? if so can someone please tell me where each of these wires go? I have a wiring diagram so please dont give me a link to another. It is not helping. Anyone that can help me out?
did you ever ever fix the problem? My car is reading the same thing.
Old Mar 8, 2020 | 10:39 PM
  #88
Genia88's Avatar
My 1991 Chevrolet Camaro Rs was having the same problem. I got a new battery and change out my alternator 2x. After basically giving up on it for a year I then check all fuses located at the driver side underneath the steering column. Comes to find out the fuse for the C/H fan didn't have a fuse in it. Now that I had put a fuse my voltage reads 13.8-14.2. So far my car not losing power. Hopefully this helps a little.
Old Sep 8, 2022 | 11:09 AM
  #89
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Having the same issue with a new/remanufactured alternator not charging, I'm using an alternator for a 7.4 454, same electrical connections as the factory 91 alternators, it's the mounting points that I needed.
Both the 91 454 and the 91 350 use a CS-130 alternator. Are all CS-130 alternators internally wired the same? Is there a difference in the voltage regulators?
Fuses are good, all wiring associated with the alternator has been double checked, voltage is where voltage needs to be I even jumpered the battery post on the alternator to the "S" pin on the connector as suggested by Tuned Performance in post #2, still the alternator was not charging. I've had this alternator tested twice, once a few months ago and the second last night, both times it past at my local AZ.
Random thought... the adapter plug that is used for the testing machines, is there a different alternator adapter plug for a 1991 7.4 454 big block and a 1991 5.7 350?
Old Jun 8, 2024 | 10:43 PM
  #90
Donp33zy's Avatar
Ima replace the alternator again after work.
Maybe when you're guys are hooking up a power why not unbolt the alternator bolt where the "alternator ground to the motor block" and run a ground wire that goes to your battery that way while the positive terminal wire running to the red on the alternator(alternator charging point)to the battery's positive terminal post it should be it's own unit charging
sam24th
Jul 12, 2011 06:05 PM
BCdawg57
Jul 13, 2008 12:36 PM
Wesdog
Dec 22, 2003 05:37 AM
justicefurall
Oct 21, 2002 12:17 PM
