89 Rs. Park/headlights make right half of dash gauges stop working
Old Nov 29, 2011 | 08:42 PM
89rscamaro89's Avatar
With the dash lights or headlights on, the right side of the dash (IE: rpms, oil psi, battery) all drops to 0 and they do not move.
If I adjust the dimmer to where the dash lights are off while the headlights and park lights are on, then the gauges work again, but when I adjust it to where it's back on, the gauges stop again. Yet, if the park/head lights are OFF, the gauges all work perfect.
I already replaced the dimmer and park/head light switch with a brand new one. It did not change a thing.
All lights work, turn signals, high beams, low beams, tail lights, emergency lights.
Old Nov 30, 2011 | 02:25 PM
GILLIGAN's Avatar
Car: 1992 RS
Engine: BLACK&DECKER AQUARIUM PUMP
Re: 89 Rs. Park/headlights make right half of dash gauges stop working
Is your chime box working? Try disconnecting it and see what happens i have seen these cause problems when the short internally
Old Dec 2, 2011 | 01:17 AM
Ok, thanks for the advice! I will try that!
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
marcusaw
Aug 10, 2015 08:13 AM
