Distributor Upgrade
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
Distributor Upgrade
Hows it goin guys I usually post on NYTHIRDGEN. I have a Vortec 350 crate motor and the stock ignition coil bracket doesnt work. My friend told me about a MSD HEI Distributor that has the coil on it. Can someone post the link to this please.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Distributor Upgrade
I don't think msd makes any hei's that are for ccc vehicles only the replacement hei with vacuum advance and late model replacement like your external coil model. you can use a 85-86 tpi hei or older ccc car or truck hei. you will need to convert the harness for the high and low ecm signal and change the end for hei power and tach if installed.
