89 t/a with crsecntrl no brake lights
Old Dec 11, 2011 | 03:35 PM
firestein's Avatar
Car: 89 T/A
Engine: 5.7
I tried searching it couldnt find anything, my 89 trans ams brake lights have been out for 3 weeks now, only 1 bulb is burnt out in the back, i replaced the brake light switch checked the fuses, and they are still not working, any ideas?
Old Dec 12, 2011 | 12:10 AM
amlv20's Avatar
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
Re: 89 t/a with crsecntrl no brake lights
power/ground issue, circuit/ connector issue.
Old Dec 12, 2011 | 12:55 AM
seibertjd's Avatar
Car: 1984 Camaro Z28
Engine: SBC 350
Transmission: B-W T5
Take a look at a wiring diagram, make sure that all of your wiring is correct. Make sure nothing is cut, corroded, broken, etc. Make sure all your grounds are clean. Are you sure both lights aren't burnt out? Replace at least the one that is burnt out, make sure all your connections to the bulbs are clean and serviceable.
Frozer!!!
Jan 19, 2024 04:55 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
