Need help figuring out 4 wires..
Old Dec 12, 2011 | 03:25 PM
silentkillzr's Avatar
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
I need help figuring out 4 wires, ive sorted and fixed the whole harness except the wires by the back of distrib. ( i have an 84 bird ). original v6 car, v8 swapped. I assume the 4 wires will be Battery to distrib, Tach, Oil Press, and Temp gauge. Anyone help? Ill go try and figure out colors on them tonight. is there anyway i can test the wires and see which gauge moves?
Old Dec 12, 2011 | 03:32 PM
crazymonkey16's Avatar
Car: 1990 Camaro RS
Engine: L05 TBI
Re: Need help figuring out 4 wires..
Maybe this is a dumb question... are you running carb or EFI?
Engine: 357
Carb of course. Id be far more confused than 4 wires with efi. Lol
Old Dec 12, 2011 | 03:42 PM
Car: 1990 Camaro RS
Engine: L05 TBI
Haha, it just threw me for a second when you didn't mention ECM... I had to rewire my ignition setup last year and had to figure out my wiring too, and the way I did it was ohm metering the wires to their respective connections on the ECM... I'm not gonna be of any help on your setup though. Sorry.
Old Dec 12, 2011 | 03:43 PM
Engine: 357
Oh okay, Well thanks for your input, the battery/ign to dist should be easy, the other 3 ill have to figure out what ohms to send it, and how todo that efficiently lol
Old Dec 12, 2011 | 07:12 PM
Pocket's Avatar
Car: 91 Trans Am
None of those wires changed from the V6 to V8 conversion and lucky for you, they never changed from 82-92, so ANY 3rd gen harness will have what you need
You want F4 (PNK), D6 (WHT or BLK/WHT), E5 (TAN) and F5 (DK GRN) respectively
https://www.thirdgen.org/forums/ltx-...formation.html
Old Dec 13, 2011 | 01:09 PM
Engine: 357
Thank you so much Pocket! life saver.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
