Swapping a 145mph speedo
Old Dec 18, 2011 | 11:24 AM
reride's Avatar
Car: 1989 IROC-Z Convertible
Engine: 5.7 TPI
Axle/Gears: 3:23 Posi w/ alum. driveshaft
Before I attempt to swap a 145mph speedo into my '89 Iroc can anyone tell me if it's a simple plug & play type install or if there is anything else is required to make it work correctly? Thanx in advance!
Old Dec 18, 2011 | 11:32 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Swapping a 145mph speedo
Plug and play as long as you're swapping in a mechanical speedo (for the 145 that's 86-89). I'd swap only the speedo head in to avoid possible electronic gremlins.
JamesC
Old Dec 18, 2011 | 11:56 AM
reride's Avatar
Engine: 5.7 TPI
I don't recall seeing a speedo cable on the trans (700R4), or would the cable be somwhere else? It is possible that it too was swapped buy previous owner, as the motor, sway bars, rear end and brakes don't match the spid sticker.
Old Dec 18, 2011 | 12:10 PM
JamesC's Avatar
If your current OE speedo functions, it's mechanical and will have a cable from the 700R4.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
ChevyZ71
Aug 13, 2015 07:30 AM
