Gauge Cluster Rebuild
Old Jan 17, 2012 | 07:44 PM
ljwcox's Avatar
Car: 1992 Camaro Z28
Engine: Bolt On L-98 150shot
Axle/Gears: Stock
Hey anyone know of a good place that would rebuild my guage cluster out of my 92 z28? Half of my lights do not work and my odometer dose not work anymore either.
Old Jan 18, 2012 | 12:02 PM
85irocinjected's Avatar
Car: 1991 RS
Re: Gauge Cluster Rebuild
Its electric. Really simple to pull the cluster and replace the lights. Most replace them with LEDs. Just do a search for gauge cluster LEDs. The speedo issue can usually be solved by replacing the VSS if its not working or tracing which wire is broken if the VSS is working. If you have a TBI engine then you also have a VSS buffer box which will need to be replaced it is non functional. The speedo circuits on our cars are very simple so it should be no problem for you to fix these issues.
Old Jan 18, 2012 | 12:26 PM
ljwcox's Avatar
Axle/Gears: Stock
VSS is vehicle speed sensor correct? where is it located? and i know for a fact that one of the light bulbs isnt burnt out it is the plastic socket that the bulb slides inside that twists into the back of the cluster. the "socket" is broken dose anyone know where to buy those?
Old Jan 18, 2012 | 08:46 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Just go pocket some from the wreckers.
Old Jan 18, 2012 | 10:20 PM
ljwcox's Avatar
Axle/Gears: Stock
Haha alright well thanx ill **** with it this weekend then, n try n go to the junk yard
Old Feb 2, 2012 | 07:31 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
autoinstruments.com
Old Feb 2, 2012 | 07:35 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Your '92 gauge cluster is different than my '86 but replacing the light bulbs is really no big deal. Mine has I think 11 bulbs just for the dials. Sorry I can't help with the speedo.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TrevinE
Sep 14, 2015 03:20 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
90formulaVortec
Sep 8, 2015 12:42 AM
