87 Maf ECM - How does the ecm see the VSS signal?
Old Jan 17, 2012 | 09:12 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
On a 1987 L98 MAF ecm how does the ecm see the VSS signal? 2000 or 4000 ppms?
Old Jan 18, 2012 | 12:46 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 87 Maf ECM - How does the ecm see the VSS signal?
2000 on MAF TPI
4000 on MAP TPI
Old Jan 18, 2012 | 05:42 AM
insomniac's Avatar
Engine: 5.7 L98
so if i have a electric vss and speedo and am swapping in a ecm and motor from a 87 which used a cable i should be able to tap into the buffer of my now TBI car and send a wire from the 2000 ppm side right to the ecm?
Old Jan 21, 2012 | 12:28 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Have the guy who programed your aujp change the switch from magnetic vss to optical and use the input from the vss buffer to pin b10 only of the 1227730 it will then except the 2k ppm singal.
GTAman
Jul 3, 2024 07:29 PM
Fronzizzle
Feb 9, 2017 09:31 AM
BumpaD82
Feb 26, 2016 02:57 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
