ECU Computer questions
Car: 82 TransAm (45,000 original miles)
Engine: 305 TBI Cross-Fire
Transmission: 3 speed automatic
Hey I am new to this website. I am told that ODB-II didn't start until 1996 but i can see that my 82 Firebird has the 12 prong plug for engine diagnostics. I would like to buy one of the displays that shows active engine data. These devices say that they support ODB-II but then what about my car? The plug appears that it would fit. If someone could please enlighten me that would be great.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: ECU Computer questions
your car is OBD1
OBD2 has a 16 pin connector
if you have a laptop computer, you can buy or make an ALDL cable, download the right software and scan it.
ALDL Cables are available here for less than most other places.
http://www.reddevilriver.com/aldl.html
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: '83 Camaro Z28
Engine: "Just a little something"
Axle/Gears: 3:73
Are you looking for a chip, a scanner or just to be able to see some engine data? There really is not a whole lot to "see" on an 82. If you are having some issues and need a scanner to be able to monitor data Inovia (i think its spelled correctly) makes a nice consumer scanner that would give you the infoo you need. Will set you back $250 - $300 though. Unless you absolutely need Id save my money
eightsixseven
Dec 16, 2024 01:50 PM
