No headlights or anything.
Old Feb 3, 2012 | 04:51 PM
rattbird1989's Avatar
Car: 1989 Pontiac Firebird FORMULA
Engine: Rebuilt Chevy 350 in 2007
Transmission: 5 Speed Borg
i put my car (1989 firebird formula) away every winter and i try and start her every so often, well today she started up just fine but now the Headlights, interior lights, radio, power windows and locks or horn don't work now, my blinkers work fine, everything worked fine last summer i checked all the fuses they seem fine look under dash still all looks fine, need help because this summer i am getting a top end kit to add to the motor but would like to have all the basics back thanks
Old Feb 3, 2012 | 08:39 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: No headlights or anything.
Sounds like a fuseable link blew or anothe connector came undone. I would replace the fuses under the dash as a first step. then grab a haynes or helm manual and see if you can trace the wires. I'd also check the wires down at the solenoid, check to see if any of the wires down on it are loose or burned up.
Old Feb 3, 2012 | 10:14 PM
ill check it out hopefully its an easy fix
thanks
Old Feb 10, 2012 | 05:48 PM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Hey Just swapped in a T56 from auto and have same thing, but my windows and blinkers work. My power mirrors, radio, cig. lighter, digital odometer, heater selector, headlights, parking and fogs don't work and my systems check states OK then a minute later, states trunk open , then OK again.
I checked all fuses and 2 circuit breakers in panel, but nadda. I looked at the fuse links but these look fine.
Do you disconnect the bat? If so start there, is there a main wire you didn't hook up, if not check all positive wires near bat.
Old Feb 20, 2012 | 12:38 AM
88 TA GTA's Avatar
There is a "Headlight Door module" located beside the wiper motor, on the driver side firewall. (to the right if you at front of car looking to the back) This controls all items listed above not working. Now mine started working on its own, then shut off and started working again while looking for info on the net. There are fuse links "D" "E" and "G" in the wiring harness under the master cylinder. Haven't had issue since she fixed herself, but will keep you posted.
There is also a circuit breaker for these items. Check that too.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
