Check engine light
Old Feb 19, 2012 | 10:38 PM
88cam23's Avatar
Check engine light
1988 camaro 2.8... Ok all my guages are wrong and I am in the middle of finding a replacement cluster. But in the mean time is there a way I can make a check engine light?
Mine doesnt work on cluster and I cant get it to. so I was thinking is there a way I can plug into the wires that signal the check engine light and see if I get it come on that way?
Old Feb 19, 2012 | 11:23 PM
88cam23's Avatar
Re: Check engine light
I think I can do it if I can find a gauge cluster pin out. by finding the signal wire for the engine light then grounding the other.
Old Feb 20, 2012 | 01:49 AM
88cam23's Avatar
Does any one know if that will work... Ive tried tracing the check engine light wire into the ecm and probing it and I still dont get any light to light up or flash.
Old Feb 20, 2012 | 02:26 AM
rrf321's Avatar
Car: 91 formula
Engine: 5.7 not o.e.
Axle/Gears: 273 2 wheel drive
what makes you think it should be on? if the car is not throwing a code it will not come on, only when you first start it will it glow.
Old Feb 20, 2012 | 02:28 AM
88cam23's Avatar
Well for one when I turn on the key It doesnt even come on at all not even for a few seconds. WHen I jump A and B on the connector I get nothing at all. Bulb isnt burned out.
Trying to figure out why its not working.
What I am trying to figure it is if there is a way to bypass the cluster bulb and use a test light or another source to see if its the ECM thats messed up/
Old Feb 20, 2012 | 02:47 AM
rrf321's Avatar
Car: 91 formula
in your first post you stated your gauges were messed up,is it possible you have a bad ground on the cluster?
Old Feb 20, 2012 | 02:55 AM
88cam23's Avatar
Maybe so? I havent checked.. I just know I get no indicator lights what so ever . No brake,choke,check engine,seatbelt. None of those lights work.
Might sound like a dumb question where is the ground for the cluster at? Is it one of the wire clips that plug to the back of it?
Old Feb 20, 2012 | 03:05 AM
rrf321's Avatar
Car: 91 formula
http://www.austinthirdgen.org/index.php?pid=19 a wiring diagam for your car is here
Old Feb 20, 2012 | 03:24 AM
88cam23's Avatar
Thank you for ur help.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
