GTA taillights
Old Feb 5, 2012 | 03:51 PM
Pajjen's Avatar
Car: Pontiac Trans Am GTA -87
Engine: 5.7 TPI
GTA taillights
Can someone be very kind and tell me the function of GTA taillights on a -87? I have imported the car and the taillights was modified for another country and now i want to make them original. So i need to know the function to know what they changed in the wiring. Also if someone know the wiring, it would be great.
Thanks.
Old Feb 5, 2012 | 05:15 PM
mrrman's Avatar
Re: GTA taillights
Thanks.
I posted a manual on this site for an 88 TA ( my car is an 87) It should have all the wiring diagrams you need.
Old Feb 5, 2012 | 05:33 PM
startat2's Avatar
Re: GTA taillights
Not sure where you are from, but you can likely find a tail light harness and have it shipped. There is a single plug in the DS back hatch and the whole harness removes. Esp if yours is hacked it would be worth it.
Old Feb 6, 2012 | 11:51 AM
Pajjen's Avatar
Engine: 5.7 TPI
Re: GTA taillights
Thanks for the answers. But i dont going to buy a harness for only some small mods. I just need to know the function.
The inner white are reverse. the 2 sections in the middle is running lights and brake lights, should they flash too? or just the outer section?
Should the outer section just flash or should it also be brake and running light?
Anyone have a GTA? or a trans am? with those taillights. Im not sure if every trans am have these taillights. but at least the GTA:s should have.
Thanks.
Old Feb 10, 2012 | 05:51 PM
88 TA GTA's Avatar
Car: MSD Dist., Crane Hi 6 ignition
Engine: 350 - 50 over, S/R Torquer Heads
Transmission: T56 - Originally a 700R4
Axle/Gears: 9 bolt posi with 370
Re: GTA taillights
Thanks.
I do,
most inner are back up lights, next two out are parking lights as well as brake and signal lights, the 3rd light out is only a parking light (I believe), mine ride is stored right now and has been for the last year and a half, saving for a 6 speed swap after 700R4 started slipping, I will check just to be safe, if I don't re-post by Monday the above is correct at least for an 1988, they did change to orange singal lights later on....but if you imported a 1987, it would be the same as the 1988
Old Feb 10, 2012 | 05:58 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: GTA taillights
I have a 87 GTA. The 4 bulbs are set up as follows:
Reverse.....running tail lights & turn x2 bulbs.....running tail light only
Old Feb 14, 2012 | 03:04 PM
Pajjen's Avatar
Engine: 5.7 TPI
Re: GTA taillights
Thank you very much for answers!
F-body-fan
Jan 12, 2023 01:49 PM
sheachopper
Jul 31, 2019 11:27 AM
bjpotter
Oct 4, 2015 07:48 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
Navy8125
Oct 1, 2015 11:24 AM
