starting issue
Old Feb 9, 2012 | 09:33 PM
towtruckman's Avatar
starting issue
I have a 91 Camaro went to the store, got back home parked it. Next morning turned the key dash lights, radio works, motor would not turn over no noise not even a starter click. I checked battery -good, checked starter- good, I checked the switch on clutch -good. I also checked 1 and 3 fuse both -good. I was wondering about the chip in the key. If there was an issue with it or the ignition would that totally kill it? or would it turn over but not start? If you have any other ideas lets hear them!! is there an inline fuse some place? THANKS
Old Feb 10, 2012 | 09:44 AM
mrrman's Avatar
Re: starting issue
If theres a chip in the key, look at the posts about " VATS" or " Vat Systems" This will bypass the security on your car.
Old Feb 10, 2012 | 07:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: starting issue
VATS takes out both the starter ( no crank ) and the fuel injectors ( no fuel )
Read
https://www.thirdgen.org/vats_passkey_system
Old Feb 10, 2012 | 09:35 PM
Re: starting issue
Great thanks that help a bunch, I will get my meter and see what I find thank you
Old Feb 12, 2012 | 07:40 PM
Re: starting issue
After standing on my head for a bit I found the 2 wire connector. When I checked it with my volt meter I get nothing, with the key just stuck in or all of the way to start. Does that point to a broken wire in colum? or have I failed to do some thing? Thanks T
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
