Wiring switch into fan relay
Old Feb 11, 2012 | 05:54 PM
THETANK's Avatar
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
I want to wire a switch into my fan relay so I can manually turn the fan on yet still allow the switch in the block to automatically turn the fan on. From what I read in other posts I can hook the switch into the green wire on the fan relay to accomplish this.
1) What amp rating should the switch be?
2) do I need to run a fuse between the manual switch and the relay?
Old Feb 11, 2012 | 06:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring switch into fan relay
Originally Posted by THETANK
I From what I read in other posts I can hook the switch into the green wire on the fan relay to accomplish this.
Correct.
Splicing the manual switch into the wire ,grounds the relay to operate it the same way the ECM does.
Circuit is already fused with 3A fuse so 3A or better rated switch would work.
Is only the low current control side of relay
Old Feb 13, 2012 | 08:20 PM
THETANK's Avatar
Car: 91 rs
Excellent, Thank you
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Dialed_In
Aug 20, 2015 01:45 PM
355sbcTPI
Aug 19, 2015 04:38 PM
