need some diagrams for electric hatch
Old Feb 17, 2012 | 02:46 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
so its about that time that i get to take the body harness out of my 85 and swap it to my 92 you may ask why im doing this well simple because the 85 has power but the hatch mechanism is different than the 92's. so question is how can i get the 92's hatch mechanism to wire up to the 85;s harness? and how can i use the 85's switch to work on the manual opening mechanism? does that make sense? if anyone can help me id appreciate it diagrams would be best
Old Feb 17, 2012 | 03:53 PM
1983Chimaera's Avatar
Car: 1988 Camaro IROC-Z
Engine: LB9 (305 TPI)
Axle/Gears: 2.73 Positraction
Re: need some diagrams for electric hatch
I managed to get a hatch release to work in my '83 Z/28, using a modified harness from an '85 Firebird (dash and rear harness). It's not that difficult, you're basically using a relay (any 12V accessory relay will work) that routes 12V power to the rear hatch release, and a switch that completes a 12V circuit energizing the coil in the relay by grounding thru the switch. You should also route the circuit thru the neutral safety circuit so the hatch can only be opened in Park, but this is not necessary...just a good idea. The hatch release itself grounds to the body at the rear of the car, I used a self tapping metal screw to do so on my car. I have both the original print of the Haynes manual (with the old much more detailed style diagrams) and the current later style Haynes manual (with the simplified diagrams). I can make copies of each tonight for both the '85 and '92 cars, and post them if it helps. I don't think you'll need them, the circuit really is rather simple.
Old Feb 19, 2012 | 10:14 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I dont think the power hatch its self will mount to it as the bolts holes are in a different location all together. Might want to see if the motor bolts to the body first or you will need to cut a bracket out of another car and weld it in. Im not 100% sure of this tho. Im gonna be putting one in my friends 82 come spring and the mounting holes dont even come close to lining up or being on the right angle. I know 91 -92 ones where smaller so that might work for you
Old Feb 19, 2012 | 10:45 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
right right i was saying i wonder if i cant make the 92's hatch open with the switch. i know they dont line up i already tried that. the 91-92 was bigger, it has that vacuum assist or whatever
Old Aug 12, 2012 | 01:43 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
ok so im working on the hatch now i dont feel like switching the actual hatch mounts, my 85 has the hatch release button and i have the harness in but i just dont know how to get it to work with the 92's power hatch so i can have the center console hatch button
jrdturbo
Mar 31, 2016 02:58 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
formula00ra
Sep 28, 2015 11:50 AM
