Wiring Pro.
Old Feb 18, 2012 | 10:08 AM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Wiring Pro.
On a 87 iroc under hood their are 2 seperate plug ins that go to the firewall a big one an one that only has 7 pins to it what are the wires that are used in this an the colors if anyone knows. I trying to get rid of the wires I dont need. I went to carb. an dont need all of them. any help would be good. Thanks.
Old Feb 19, 2012 | 10:21 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Wiring Pro.
Are you talking about the C100 on the driver side splitting in 2 pieces?? If so you will need most of the wires on there and id leave them alone as if in the future you end up doing a LS swap or something fuel injected you will need them. Thats just my 2cents tho.
Old Aug 21, 2012 | 11:04 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Re: Wiring Pro.
Here is a good site local to me. Alot of info. Click your year. Lmk if this helps...
http://berlinetta.info/C100.htm
Old Aug 21, 2012 | 01:44 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Re: Wiring Pro.
If you want email me or call I can go over the wires out of my helm for 89 if you need to clarify. Small connector is the headlights foglights and such. Most important is the large red,purple and key on power pink from ignition. These power the whole car off the starter which is tied to battery. Most wires you wont reuse. Gauges to work you will need to keep things like oil pressure sender, coolent temp, voltage, fuel sender is seperapte under drivers side carpet near door sill. Tach is there but if you are running a msd you can tie it into that. The fat pink key on wire is the keyed 12 volt wire needed to trun on msd when you turn on ignition. Things like cold start, injectors, etc, that had to do with efi are not used. Lmk, take care.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
