hatch switch issue
Old Feb 19, 2012 | 07:50 PM
User Error 87's Avatar
Car: 1987 Trans AM GTA
Engine: 5.7 TPI
Axle/Gears: 3.73 POSI
hatch switch issue
so my 1987 trans am gta switch for the hatch isnt working. The motor in the rear is working..pops up when the trunk opens and pulls the trunk down to close it...but when i sit in the car and press the switch to pop it the brake light on the dash goes on...so i figured id press the switch while the e brake is up or depress the brake..nothing...any ideas
Old Feb 19, 2012 | 08:07 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: hatch switch issue
My guess is the relay in the console. I have a similar problem at the moment, except my relay is shorted and keeps the release solenoid energized - it clicks about every 2 or 3 seconds and the hatch won't stay shut. I just unplugged the solenoid until I can get a new relay since the key and pull-down motor work just fine. Even with the solenoid disconnected, I get the brake indicator in the dash every so often, moving the release switch (as if to open the hatch) will make it go out.
Old Feb 19, 2012 | 09:07 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
If the hatch isnt closing all the way than it wont release until it has.it has to make a click sound at the end of closing.this can also drain your battery dead.my nylon guilds are worn and the asembly gives a little at the end.
Old Feb 19, 2012 | 09:31 PM
Engine: 5.7 TPI
mine closes all the way..u hear the click...im going to check out the relay..i did order a quality used one from hawks...hasnt come yet..
Old Feb 19, 2012 | 11:02 PM
jaymzallyn's Avatar
Car: 89' Camaro RS
Engine: 2.8 MPFI
Transmission: borg warner 5 speed
Axle/Gears: stock
I grounded out a hot lead a few years back and mine quit working. I just ended up hard wiring mine using the existing switch. Ran a new hot lead under the carpet all the way back to the motor. The only concern for some may be that the switch is active at all times now. I haven't had any issues with it, if anything it's more convenient for me, although I don't have any kids or pets who ride in my car.
Street Lethal
Apr 30, 2019 12:14 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
