oil sending unit
Old Feb 19, 2012 | 07:34 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
oil sending unit
Any links to the wiring diagram of the oil pressure sending unit, I have 2 wires to trace, tan/wht and an orange.
Need to hook up without engine harness.
Old Feb 19, 2012 | 08:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: oil sending unit
Old Feb 19, 2012 | 10:32 PM
transamice's Avatar
Car: 87 GTA t-top
I got rid of the whole harness, do I need the fuel pump relay for the oil sending unit to work?
Was hoping to work around that with a relay just for the sending unit itself.
Trying to minimize stock harness wiring as much as possible.
Old Feb 19, 2012 | 10:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
In vetteoz diag - fuel pump switch is the oil pressure switch
Old Feb 19, 2012 | 11:12 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Works the other way around from what I've heard. If by chance the fuel pump relay fails, the fuel pump will get power from the oil pressure switch after pressure builds. Will be a long crank before start if ever the relay fails.
Old Feb 19, 2012 | 11:33 PM
transamice's Avatar
Car: 87 GTA t-top
The Holley setup comes with a fuel pump relay, I was hoping to use that instead of the stock relay.
Its only 2 wires to get the oil sending unit working, orange 12v and the tan/wht signal, with a relay it should work, although Im not sure where to connect that tan/wht wire.
I thought it would be a connection under the pass side dash where the engine harness connects.
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
