86 t/a rear hatch wiring
Car: 86 trans am
Transmission: 700 r4
Axle/Gears: 3.42 posi 10 bolt
does any body have any info on the rear hatch wiring and connector location for the power and ground that goes to the hatch release button? I just picked up a project that someone had installed a clifford alarm system in and most of it is missing with wires cut under the dash so i have reconnected all the wires that were hacked into every thing works now except the rear hatch. The plug to the switch in the console is there it has a small orange wire and a large yellow or maybe tan wire and I cannot find where it plugs into any help would be appreciated thanks.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: 86 t/a rear hatch wiring
do you have a pic of the plug? the hatch wiring is split into 2 parts the front half and the rear half and there is a plug with those exact wires that they plug into.
