adding low fuel light?
Old Feb 21, 2012 | 09:23 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
my buick has a low fuel light and id like to add one to my camaro.i wonder if theres a sending unit that will also fit a camaro that has the low fuel light built in?has anyone here done that?
Old Feb 22, 2012 | 06:42 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: adding low fuel light?
Low fuel light is part of the dash; not the sender
"GM fuel sending units operate in a range between 0-90 ohms.
Zero ohms correlates to "empty" and 90 ohms correlates to "full
The low fuel light is energized when the sending unit provides a 10 ohm signal to the fuel gauge."
So you need to design some electronics to turn a light on at what ever Ohm value you wish
using the wire from the tank sender
Read
https://www.thirdgen.org/forums/elec...light-our.html
Old Feb 22, 2012 | 10:42 AM
zenish's Avatar
Engine: 305 tbi
thanks.i hope he has some made to sell.
Old Aug 1, 2012 | 03:45 PM
prplroc92's Avatar
Car: 1992 25th Anni. camaro
Engine: 5.7 liter ZZ4 swap TPI
Transmission: T56 (manual 6 speed)
Axle/Gears: corp. disc GM 10 bolt, 3:42
The 77-82 corvette uses a three wire low fuel light. +,- and a 90-0 ohm signal. Seller on ebay has replacement light modules for $30.00. Sellers name is markohpe. If you buy the module from him just ask for the wire diagram for the light module. I have it on my 92 camaro and it works great. Hope it helps
Old Aug 1, 2012 | 04:01 PM
Twin_Turbo's Avatar
VDO has already done all the hard work. They sell a make point switch in their marine line which is adjustable and will work with the stock gm senders ohm range, used it multiple times
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 19, 2015 01:36 PM
mizz0313
Aug 12, 2015 06:45 AM
Omega
Aug 10, 2015 12:46 PM
