Problems with fuse box
Old Feb 25, 2012 | 09:03 PM
chaserob's Avatar
Hey there, I have a 1990 camaro rs and I've been trying to work with my fuse box to install a cb radio, but no luck. I'm really confused by the fuse box, it looks as if it's newer than what I'm used to, the traditional soldering method for basic things. My fuse box has cartridge type fuses that I can pop out with 2 metal pieces, I'm not sure how I'm supposed to wire that in? Sorry, probably a really simple question but any help would be greatly appreciated!
Old Feb 25, 2012 | 09:19 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Problems with fuse box
really,,!! you dont have push in multicoloured plastic fuzes???? any way you can pull power from the battery thru a 15a fuse if you have to but i digress.you should be looking for the switched power 'acc ' on the fuse box .unless theres been drunken monkeys under there.its anyones guess. go sideband with a amp,youll walk waaay out there! good luck!
Old Feb 25, 2012 | 09:31 PM
chaserob's Avatar
Actually mine are the plastic ones, look kinda like cartridges. Ive located the acc, I'm just not sure how to physically get the wire in there, wrapped it around one of the metal ends? Or what?
Old Feb 28, 2012 | 04:28 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Breaker One Nine
The Midland 13-880B.
Best sideband on the planet.
Transmit frequency is also adjustable where others only adjust receive.
You should not tap into the fuse box front because when the CB has a problem it will blow an automotive fuse which might leave the car disabled.
You should run a dedicated fuse connected to the B+ coming into the car from the firewall.
Size of the fuse should be indicated on the back of the CB.
Happy Racing!
My Brakes Don’t Work AT ALL When The Car Is In The Air
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Moore89
Aug 24, 2015 07:06 PM
justin57
Aug 20, 2015 07:05 PM
