89 Camaro snipped fan wires
Old Mar 8, 2012 | 08:07 AM
Ricks 89RS Conv's Avatar
Car: 89 RS Convertible
Well, the weather is warming up a little so it's time to get my 89 vert project running. I was installing a new fusible link on the distribution block to Alternator wire when I noticed the previous owner had snipped the electric fan wires. Both ends just laying there with no indication anything else was done. I do know some people will wire the fan to a inside switch but I want everything working as it should. I think my first step is to apply power to the fan and see if it works so does anyone know if the black wire with the red stripe is + or -? What should I check after that? The sending unit? Wiring? Any help would be great!
Old Mar 8, 2012 | 09:05 AM
dlambunion's Avatar
Car: 1990 firebird formula 5.0
Engine: 305 tbi
Axle/Gears: 2:73
Re: 89 Camaro snipped fan wires
IIRC the bk red wire should be positive. mine were cut and put on a switch. but the switch broke. I found the bk and bk red wires cut next to pass side engine bay wheel well. just reconnected them and all worked well.. just run the black to a ground and connect a jumper to touch to bk red to the pos. battery terminal to see if it works before running wires for a switch and all...
Old Mar 8, 2012 | 09:47 AM
Thanks. I will try and connect them back up after I test the fan. I hope I get as lucky as you did. The car isn't running yet because of VATS issue but hopefully I can fix that and see if the fan will cycle as it should.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
rocn7roc
Sep 21, 2021 02:16 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
