Working speedo gauge without ECU
Old Mar 9, 2012 | 03:06 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Im running an 87 TPI auto Firebird with aftermarket ECU, what is needed to get the speedo working?
Do I need to connect a wire (light green or brown) from the vss buffer box to...?
Old Mar 9, 2012 | 04:39 PM
utilityguy2's Avatar
Re: Working speedo gauge without ECU
If your car is same as the Camaro then you have a mechanical cable driven speedometer. The VSS is in the speedometer head and sends a 4000ppm signal to the buffer box which sends a 2000 ppm speed input to the ECM (stock). Check for broken cable or inoperative Speedometer.
Old Mar 9, 2012 | 05:49 PM
transamice's Avatar
Car: 87 GTA t-top
Its not mechanically driven and the cables are good.
Old Mar 9, 2012 | 05:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Old Mar 9, 2012 | 10:33 PM
transamice's Avatar
Car: 87 GTA t-top
I connected the green wire from the buffer box to the brown wire that was connected to the vss on the ECU. Didnt work.
WHat am I suppost to connect to?
Old Mar 9, 2012 | 10:38 PM
Engine: Lb9
Transmission: M20
lt green to speedometer and the input to the ecm will determine on what ecm you are using and the specified input
Old Mar 10, 2012 | 02:49 PM
transamice's Avatar
Car: 87 GTA t-top
Figured it out, I had no ground to the buffer box, grounded it and speedo works fine.
BRoss99
Aug 10, 2025 05:08 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
beachrodder
Aug 7, 2015 04:27 PM
