87 camaro ignitionsystem problems
Car: 87 iroc camaro
Engine: 360
Transmission: Turbo 350
I have replaced every thing in the ignition system and still no spark the guy who had it be for me did a custom wiring job I drove it home no problem then one day I go out to start it nothing looked at the plugs cap rotor and disturbitor looked really warout so I replace them with msd spark plugs and got an accel distributor cap and rotor still no spark and did not get the coil yet but I know its good I put it in my 80 Corvette and started right up
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Customs Violations
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the primary of the coil when the key is in the RUN position.
Is there power?
If no, there is a bad or burned out connection between it and the ignition switch, or power to the switch.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Is there power?
Happy Racing!
92camaroJoe
Aug 13, 2015 06:07 AM
