Bad alternator?
Old Jun 18, 2012 | 11:22 PM
  #51
SKELITOR117's Avatar
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Re: Bad alternator?
Take your car to an auto shop. Have them test it under a load. Mine tested good at 3 DIFFERENT auto parts stores. Then I took it to a shop and it tested bad under a load.
Old Jun 18, 2012 | 11:38 PM
  #52
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Re: Bad alternator?
An old trick to see if an alternator is working is to stick a metal screwdriver to the rear shaft and see if it is magnatized. If it is making juice it makes an electromagnet and the screwdriver will stick to it.
Old Jun 19, 2012 | 10:15 AM
  #53
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Bad alternator?
I will have to take it to the shop and have them look at it.
That does sound like an easy test
Old Jul 29, 2012 | 01:21 PM
  #54
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Bad alternator?
So I am still having a problem. I just killed my 3rd batt in 3 months and tested the alt 4 times in a row and it passed. The batt has 12.51v so that's bad. It is looking more and more like a short some where
Old Jul 29, 2012 | 02:25 PM
  #55
evilstuie's Avatar
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
Re: Bad alternator?
what amp rating is your alternator?
I'm using a 70A alternator replacement on my car and it's barely enough to keep it going. Every month I have to hook the battery up to the charger and bring it back to full.
Also it's a 1 wire alternator, and for some reason doesn't charge until the car has revved over 3000rpm which is a bit wierd.
What I'm going to do is buy a $5 multimeter off ebay and run it from the battery to the dash and set it up there so i have a constant readout of the voltage and can see if it's charging or not, i don't quite trusts the dash cluster gauge.
Old Jul 29, 2012 | 03:10 PM
  #56
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Bad alternator?
It might be better to get the higher amp alt. i know that alts don't put out peak charging until higher rpms
Old Jul 29, 2012 | 04:56 PM
  #57
evilstuie's Avatar
Re: Bad alternator?
yeah i'm gonna get one of the 200amp ones from the states which i think has 120a at 800rpm idle.
Cheaper to buy it over there and ship it (shipping is half the cost) than it is to buy a 70amp one here.
damn Australia!
Old Jul 30, 2012 | 04:31 AM
  #58
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Bad alternator?
Heh I agree, been taking advantage of the high AUD this year myself
Old Jul 31, 2012 | 12:59 PM
  #59
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Bad alternator?
I think mine is a 140amp I need to check it again
Old Jul 31, 2012 | 04:47 PM
  #60
evilstuie's Avatar
Re: Bad alternator?
Yeah I want to get a 383 stroker kit and rebuild kit from the states, but the shipping just kills you. $600 for the kit, $500 shipping, its ridiculous.
Old Jul 31, 2012 | 08:59 PM
  #61
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Bad alternator?
True, but I'm finding that even after eating the shipping cost, it's usually STILL cheaper than buying stuff locally. Unless it's something really massive like a block, heads etc.
With the current exchange rate, my rough rule of thumb is take Summit's price and add 80%. That's about what the shelf price for an item will be here from a large parts house (eg Rocket, Superplus, Engine Masters etc). If I can get it OS for less including shipping, I'll do that.
Old Aug 23, 2012 | 04:29 PM
  #62
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
Re: Bad alternator?
Alright I think I found the problem. When the alt is not under load it is generating about 14v under a load it drops to around 12v or less. Sounds like the regulator is bad or the diode which in turn is shorting out the Batt. I also did a different test where I think someone on here sujested is while the car is running disconnect the neg batt cable and see what happends. Well when I did the voltage dropped and the car began to shutter.
So next question is rebuild this one or get a new one. It's not my dd so I want to try to keep costs down. Anyone know of good rebuild kits
Hotrodboba400
Dec 10, 2019 07:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sahlomonic
Sep 20, 2015 07:15 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
