Testing MAF... It should glow, right?
Old Aug 23, 2012 | 04:36 PM
Y_B_A_FOOL's Avatar
Axle/Gears: 10bolt4life
Does anyone know if the MAF should be glowing at idle? All the power to my MAF checks out ok, but it doesn't glow. It doesn't seem to glow when I remove it from the intake path and the car is running (MAF is still plugged in). I'm only getting like 1.4volts from the MAF to the ECM, I believe it should be 5volts… Can anyone help me out?
Old Aug 23, 2012 | 06:10 PM
Y_B_A_FOOL's Avatar
Re: Testing MAF... It should glow, right?
Bump
Old Aug 23, 2012 | 08:41 PM
camarorookie's Avatar
Glow? The MAF burn off relay will close when you turn off the car and the sensor wires will burn hot, glow, for a couple of seconds. That is the only time the sensor wires should "glow".
The voltage the MAF sends to the ECM is dependent on how much air flow is detected through the MAF. Low air flow, low voltage. High air flow, higher voltage.
Old Aug 23, 2012 | 10:50 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
If you are testing the MAF volts at idle, that seems a little high but could be normal for our cars. Each vehicle with MAF is a little different, but MAF readings at idle should be around 0.7v to 1.2v depending on vehicle. So 1.4v could be normal.
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
