Is having 2 fuses for same item okay?
Old Aug 24, 2012 | 06:16 AM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
I need to run Ignition On power to three more places. Because I don't want to cause problems, I bought a 3-fuse fuse block that is Ignition On hot. I plan on running a fuse tap to the supplied relay and that will give me my three locations.
The only potential issue I see is, one of the spots i need the Ignition On hot is for my new wiring harness & ECM. The harness came with a built-in fuse block including one that is for the Ignition On wire. So, if I wire this to my new fuse block it'll have two fuses in it. I know it's not ideal, just wondering if it'll cause any problems? And, should both fuses be the same amperage or should I make one a little higher (i.e. 10 amp & 15 amp) so that I pretty much know which one to look for in the event of a problem?
Old Aug 24, 2012 | 07:06 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Re: Is having 2 fuses for same item okay?
Make them both the same.. Idealy only one is needed though
Old Aug 24, 2012 | 07:27 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That is how the harness is designed , gives you separate fused protection on each of those three harness circuits down stream from the main (Ign ) fuse in the car
Also simplifies fault finding because if one of the three systems is not working ( and the other two are ), you know that fuse is blown, not your main Ign fuse
Harness should have came with correct size fuses for each of the three circuits
F-body-fan
Jan 12, 2023 01:49 PM
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
bigjay89gta
Oct 15, 2015 08:04 AM
okfoz
Oct 13, 2015 02:19 PM
