No Voltage to Injectors?
Car: 1989 Iroc-Z Camaro: Sold :(
Transmission: Built 700r4
I have a Crank No Start Condition ever since I dropped my steering column? I have spark, compression and fuel. Now what?
Did I knock lose an Injector Wire?
Unplug a connector or wire that powers my Injectors and or signals them to spray fuel?
Re: No Voltage to Injectors?
Update: So I just found out that I have a Pink & Black wire that is hanging down coming from the center counsel and it looks like it should be connected straight across into the fuse box...
Any ideas as to where it goes?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pink I Think
There is more than one pink wire with a black stripe in that area however you can connect that one to a fused at 10 amp source to see if you get injection.
If you do, then permanently connect it to one of the INJ fuses.
Find out with an ammeter which fuse has no draw at this time so you pick the correct one.
Happy Racing!
I Dont Mind Wreckin On The Track, No Paperwork To Fill Out
Happy Racing!
